partwerks
Apr 10 2011, 07:05 PM
Is there any kind of an adjustment for the front hood latch?
Tom_T
Apr 10 2011, 09:48 PM
The screws on the upper (lid) & lower (trunk face) latches have some play for adjustment, but check that your lid is aligning properly too via the gaps all equal when closed. If not, then you'll need to adjust the hood first with the 2 bolts on each hinge L&R, which is easiest with the upper latch off so you can raise & lower as you tweak the adjustment.
