Full Version: What can I do with a dead flywheel?
McMark
I have a dead flywheel. Extremely worn and done for. Anyone have any ideas of 'tools' or such that I can use this for?
ConeDodger
QUOTE(McMark @ Apr 11 2011, 10:30 AM) *
Crankshaft stand for rod and timing gear assembly.
ConeDodger
If you had four of them, they could be made to be hold down for EzyUp corners.
McMark
Sleepin
smontanaro
doorstop? clock face?
Cevan
QUOTE(ConeDodger @ Apr 11 2011, 02:32 PM) *
+1
Cambo
Was that the one out of my car?
McMark
That's what inspired me, but I have a box of them.
orange914
i made a heavy grinder stand base out of a truck brake drum... why not a flywheel?
SLITS
Gold plate it and make a belt buckle out of it.
or
Send it to a well known vendor. They will list it as a "racing option".
MDG
QUOTE(SLITS @ Apr 11 2011, 07:28 PM) *
You'd have to remove some teeth for weight savings. I think the other one I saw listed had every other one removed.
You could just use it as a really dangerous frisbee.
Sleepin
trojanhorsepower
A new Olympic sport .... the flywheel toss?
Mike Bellis
Make a Killer Frizbee
or
Find a big hill, roll them down and watch the damage.
VaccaRabite
Long range target.
We hang tractor cogs out at 200+ yards at the machine gun shoot. The same 2 cogs have lasted for years, but they are pretty pock marked now.
Zach
Krieger
If you have a lathe you could cut out the center of it so you could use it for converting a 3.0 six flywheel to a push type clutch for 914 conversions.
914 shifter
r_towle
dead flywheel and dead crankshaft = one cool desk lamp.
rich
Series9
"You can make a hat, broach, pterodactyl..........
Quote from 'Airplane' the movie.
hot_shoe914
bigkensteele
Murder weapon. Not advocating. Just saying.
euro911
If you've got 4 of them, and 4 bad crankshafts, you could use them as jack stands rolleyes.gif
914Mike
I used to have a dog that would pull the screw-into-the-ground type dog chain right out of the ground. My solution was to get a big eye bolt (from a power pole, I think, about 18" long) and some big washers and two nuts. Dug a big hole and buried the flywheel so the eye bolt was just visible. Dog was still there when I got home after that! happy11.gif
Been using a _good_ flywheel for rod and gear assembly for decades now, I thought everyone did that?
pcar916
I'd think about it as a bearing surface for the teflon base bearing pads on a big Dobsonian telescope... yeah. piratenanner.gif
