Hello,
These are Weber Carbs for a Type IV designated TIPO 34 ICT. I used these for a year on my '73 914 1.7 and found them to make a lot of power but seemed overcarburated for my around the town use. I figure the jetting needed to be matched or they needed to be used on a larger/mod engine. I did not use a rebuild kit but I did clean them inside before I installed them on my car. I am currently using some bus type carbs which are not nearly as fast but matched my set up better for around town.
They have K&N filters and come complete with everything but gaskets which you can be reused off your current set-up (inject or carb) and I would recommend all new fuel line but the brass "T" will be included. You will need to rig up your own cable bracket which is true for most any carb application. Only defect is a broken dual adjustable linkage (from crossbar to carb) which was welded back and still remains adjustable on the remaining side so it works fine.
I will sell the set-up for $200 + $50 shipping (Continental US)
I have plenty of pics and larger ones at that so please feel free to email me for more info. I am new here but my Ebay name is the same and I have 22 all Positive feedback. Payment should be money order, check will work too but will delay shipping so MO preferred.
Thanks,
Diehard
