QUOTE(Bartlett 914 @ Apr 12 2011, 08:41 AM)
QUOTE(tornik550 @ Apr 11 2011, 08:33 PM)
As the title says, is this head usable? I have several heads however each set has one unique problem, I am trying to find out which I should use.
My question is regarding the large dimples in the chamber- I am not talking about cracks or other issues. (the guy that I purchased this from must have really pissed his neighbor off. He said his neighbor put a nut in the spark plug hole. In addition, F#$@ You written on the head with a sharpie)
Is that a crack to the left of the spark plug hole? I would be most concerned about cracks and the condition of the valve seats, guides and valves. There also must be enough material so fly cutting will clean up mating surfaces.
Not sure if there is a crack, it is too damaged for me to tell. This is the worst of the 6 heads that I have to choose from. I was just curious. I have another head that is in decent shape however it has some mild pitting.
How deep can they go when flycutting without causing issues?
