mrbubblehead
Apr 13 2011, 07:55 PM
im having a problem with my 914. the oil light for my 1.8, keeps coming on. never when the engine is cool. but after it is good and hot. it will come on when get off the freeway and sit at a stop sign. it comes on when im hard cornering. it even came on once after i was getting on the freeway at wide open throttle then immediately decelerate. i am running 20-50 wt oil. and 800 rpm idle. and oil level to the top line. but the problem gets worse as the oil level drops. im not real familiar with the type 4 engine. but know the type 1 very well.
i have a couple ideas for where the problem may lie.
1. oil pump is wore out
2. windage tray, or lack of.
its not a defective oil pressure switch, i replaced it with a new one with the same result. in fact, i now have oil light and an oil pressure gauge.
im pretty sure this is not normal for a type 4. but i want to ask anyways, so i can rule it out. any ideas?
Mike Bellis
Apr 13 2011, 07:59 PM
Switch to Brad Penn oil. I'm not sure the dual viscosity oil is the best choice for an air cooled engine.
If it goes on at a stop light it is...
1. low oil
2. Not enough viscosity at temp
3. bad oil sender
TheCabinetmaker
Apr 13 2011, 08:21 PM
I would do a compression test. Low compression could indicate worn rings.
Valy
Apr 13 2011, 08:39 PM
QUOTE(mrbubblehead @ Apr 13 2011, 06:55 PM)
The oil looses its viscosity with time and heat. As our engines heat-up more than water cooled engines, your engine will become W20 very fast.
Did you measured the oil amount when you replaced the old oil?
IronHillRestorations
Apr 14 2011, 06:56 AM
If changing oil doesn't help the problem, it's probably time to rebuild the engine.
Cap'n Krusty
Apr 14 2011, 07:55 AM
Pumps on these engines don't really wear out. Low oil pressure is generally a result of too much clearance in the bearings or the incorrect oil viscosity. Ring wear doesn't affect oil pressure, nor does compression. I recommend 20w50 Brad Penn oil. Anything other than 20w50 is too thin in most parts of the US, except in the midst of winter in the really cold states. Modern multi grade oils are fine for use in these engines.
The Cap'n
tradisrad
Apr 14 2011, 08:13 AM
what is the pressure gauge reading when the light comes on? I am not sure what folks think of these pressure boosting
kits
TheCabinetmaker
Apr 14 2011, 08:26 AM
Thanks Cap'n, I didn't know that. Now that I think about it, it does make sense that ring blowby would not affect the pressure from the pump. Duh!
Jeffs9146
Apr 14 2011, 12:02 PM
I had this problem on my 6 a while ago so I purchased a mechanical oil guage and installed in where the pressure sensor is to check and it was fine! So I just purchased a new sensor and all was good!
r_towle
Apr 14 2011, 12:25 PM
QUOTE(Cap'n Krusty @ Apr 14 2011, 09:55 AM)
The Cap'n
I switch out to 30 weight in the winter if I am driving...otherwise 50 weight only.
or its your bearings...
Rich
mrbubblehead
Apr 14 2011, 09:22 PM
thanks for all the input everybody.... as a bandaid, i turn the idle up to 900 rpm. and here are my new numbers.
rpm set to 900
cylinder head temp 300 degrees
oil temp 210
oil pressure 13 psi at idle
no light at idle now. but the real test will be tomorrows drive home from work. hopefully this will buy me some time. this way i hope to find a good engine core to put on the stand for a proper build. so if anyone has a cheap 1.7-1.8-2.0 laying around i am in the market. emphasis on cheap. LOL.
thanks again
doug
ArtechnikA
Apr 15 2011, 04:49 AM
Also note that the light will light any time the wire is grounded. If the wire is chafing anywhere in its run to the panel and has rubbed a bare spot, it can short-to-ground and light the light - no matter your real oil pressure...
Jeffs9146
Apr 15 2011, 07:44 AM
rpm set to 900
oil temp 210
What is the oil psi at 500 rpm's?
Cap'n Krusty
Apr 15 2011, 08:11 AM
QUOTE(mrbubblehead @ Apr 14 2011, 08:22 PM)
rpm set to 900
oil temp 210
thanks again
doug
The oil pressure may be as low as 7PSI at idle, when hot. The idle speed for a stock T4 engine is SUPPOSED to be 900-950 RPM. While the oil temp is a little high, it's not really an issue here. You said you have a new oil pressure switch. Are you SURE you have the correct switch? Many non-VW specific switches don't have the correct pressure trigger point.
The Cap'n
Jeffs9146
Apr 15 2011, 08:17 AM
ConeDodger
Apr 15 2011, 08:20 AM
You didn't by any chance put pipe thread sealing tape on the new sender did you?
reharvey
Apr 15 2011, 09:16 AM
QUOTE(ConeDodger @ Apr 15 2011, 09:20 AM)
I had this low oil pressure problem with one of my 914s. On a hot day at idle the oil pressure light would come on. I tryed all the things suggested here but the bottom line was that the main bearings were worn out.
Drums66
Apr 15 2011, 12:55 PM
......From where I sit it is hard to diagnose..try the simple things mentioned 1st!
I don't use multi-grade oils in these cars (just me) no issues!(against popular belief)
mrbubblehead
Apr 15 2011, 11:06 PM
ok i have some new numbers. just to answer a few questions. the sender is a new vdo 2 post sending unit. one for the idiot light the other is for my digital oil pressure guage. no sealing compound was used. i installed it dry.
these numbers were taken today on my way home from work. it was hot. 91 degrees here in so cal.
here we go.....
at 3200 rpm
oil pressure 39 lbs
cylinder head temp 318
oil temp 212
at 900 rpm (idle)
oil pressure 13 lbs
cylinder head temp 308
oil temp 212
this was after a 30 minute freeway drive at 75 mph.
and for those of you wondering how i came up with my numbers, i built a whole new dash with all dakota digital gauges.
silver74insocal
Apr 15 2011, 11:12 PM
hey um..you dont have enough gauges on there dude
thats f@ckin sweet
ps: sorry i have nothing constructive to add
Dave_Darling
Apr 16 2011, 02:16 AM
QUOTE(mrbubblehead @ Apr 15 2011, 10:06 PM)
at 3200 rpm
oil pressure 39 lbs
oil temp 212
at 900 rpm (idle)
oil pressure 13 lbs
oil temp 212
The oil temps and pressures sound just fine to me. Not sure about the head temps; there seem to be a lot more variables in CHT readings than oil temp readings.
--DD
ME733
Apr 16 2011, 05:42 PM
I have often wondered why no one (among the engine builders here) never suggest a simple fix to the low oil pressure problem......just place a shim (washers) inside the oil plunger pressure covers. this will give a higher tensinon to the oil pressure springs, and results in higher engine oil pressure. I think SCATT even sells an adjustable (turn a screw) spring cover cap allowing really easy adjustment....The oil passages, gallies, in the 914 are very large relative to the oil pump size. thus typical low oil pressure at low RPM,s...Rule of thumb is 10 psi for every 1000 rpm,s.
SCV
Apr 16 2011, 10:03 PM
I went through a problem with low oil pressure at hot idle when I first brought my '75 home. The oil light would flicker a bit at idle, and in the interest of taking the easy, relatively inexpensive route, I replaced the sending unit. As pointed out by Cap'n Krusty and others, there are multiple senders that fit, and they trigger at different pressures. It took a bit of digging to locate the correct sender, but that wasn't the problem. A highly-recommended, independent Porsche shop (who shall remain nameless for the moment) told the Previous Owner that it is "normal" for the oil light in a 914/4 to flicker at idle once the engine is hot. Riiight.
A closer inspection of the engine revealed the issue. The oil cooler seals had hardened and cracked slightly, causing the seals to hold when cold, but not when at operating temperature. After following the procedure on the Pelican Parts website for changing the oil cooler seals without removing the engine, the problem was fixed and remains fixed to this day. (Insert superstitious gesture here)
My oil pressure, with oil cooler seals fixed, as verified by two mechanical gauges, is 12 PSI at hot idle. (98* day, after 45 minutes on the freeway at ~75MPH). At speed, I have at least 10 PSI per 1000 RPM. Problem solved. I don't have oil temperature or CHT gauges, but will add these when budget allows.
Mrbubblehead, I'm glad you were able to sort out your oil pressure issue without major engine work.
-S
detoxcowboy
Apr 16 2011, 10:16 PM
The flickering oil temp light occasionally at idle say after a freeway run or low idle issue is not crazy, the sender for the oil temp light operates at some low calibration 11 psi? or 7psi? I forget which.. but I have went through it previously and read it in a porsche book, so not an oil issue but an idle issue.. or otherwise cause the circumstance,,.
my 2 cents, flickering light not crazy..
i remember now, it was noted again about the dummy light sender when i purchased a porche dual sender..
anyways for the books..
mrbubblehead
Apr 16 2011, 11:51 PM
QUOTE(SCV @ Apr 16 2011, 09:03 PM)
-S
thanks, but its too early to tell if its fixed or not. i didnt think of the oil cooler seals. they are not leaking. were yours leaking? or were they allowing air IN?
im guessing the seals are the same as a type 1 dog house oil cooler seals. because if so im sure i have a few left over sets....
out of curiosity, how did you pinpoint it to your seals?
i really hate to split the case to check the bearings. seems like main bearings are not easy find for type 4's. i need to find a core to build on my time. and not while being held under the gun. my teener is now my daily driver.
SCV
Apr 17 2011, 11:24 PM
Thanks for the info, Detoxcowboy. I've always associated a flickering oil light with very bad things in every other make of car or truck I've encountered. I'd never heard it described as normal, and it didn't sit well.
Still relatively new to 914s here.
Mrbubblehead, sorry man, must have misread that you had fixed the problem. Maybe I need to get more
. My seals were leaking slightly. I just followed the stain to the source. I wanted to try everything short of a complete rebuild to fix the problem as I saw it, since I could not and cannot afford a complete rebuild
done right this month. When I observed that the oil pressure switch is near the oil cooler and leaking seals, it seemed plausible that this might be the source of the pressure drop that was causing my flickering oil light. I hope your engine problem is fixed as easily.
mrbubblehead
Apr 17 2011, 11:36 PM
QUOTE(SCV @ Apr 17 2011, 10:24 PM)
no problem scv. i dont have any history on this particular engine, so i still dont trust it yet. i would feel alot better if i had one in the process of being overhauled just in case. this car is my daily driver, so i have to be careful. so far this flickering light has been its only quirck. we will see if raising the idle will buy me some time. fingers crossed. sounds like you had an easy fix. and cheap too. good for you. you saved yourself alot of dough. i love the simple fixes.
this is a bitchen little car. and i plan on keeping it. gotta keep it in top shape.
Dave_Darling
Apr 18 2011, 11:53 AM
IIRC, the owner's manual states that some flickering of the light is normal when the engine is at idle and is fully warmed up. I myself think it's a sign of a worn motor, but not necessarily a sign of a motor that must be taking off the road NOW.
High oil temps, low idle RPMs, and worn main bearings all will contribute to a lower idle oil pressure. None of them is necessarily fatal, but the light is something to pay attention to.
--DD
-JR-
Jan 15 2017, 01:30 AM
I know this thread is old, but thought I would add my 2c as I have a similar situation.
I'm running Mobile 1 synth 20-50 and have found the exact symptoms as described in this thread on my motor since it was new and rebuild new again.
I've found that the Mobile 1, while I don't have any charts on it's response, seems to thin out very quick after my oil temp clears 190F. At least that's what my oil pressure is telling me.
After oil temps pass 200F I get idiot light under 800RPM and oil pressure is reporting just under 1/2 BAR, which is the idiot light trip I believe. My engine is fairly well balanced and tuned, so it will like to idle as low as 600 RPM.
Once my oil temps pass 210F I find I can not maintain 1 bar per 1000RPM, which makes me nervous. I've added additional oil cooling with a forced air fan to try and regulate my oil temps below 210F. Works well unless I hit really hot days over 80F and traffic.
I'm running 2.2L on my engine, so I don't have a good "bead"on the concept of stock cooling managing the extra power. Personally, I want to see my oil temps under 200F.
When I said earlier that I've seen this on my new and rebuilt new again motor... I had some unrelated mechanical failures, in my top end, so it gave me a chance to look at the internals a couple times. After measuring bearing clearances I found no issues that would account for the low pressures, so don't write off your motor prematurely.
The first reply to the thread really nails it though. The oil is probably the biggest factor as long as the motor is in good shape. Running an oil that doesn't drop below 30W maybe 40W probably would help the low pressure issues at high temp. I've always run Mobile 1 synth 20-50, but after the last couple hot summers I have with the car on the road I think I'll look for something a little heavier. But I will add that the Mobile 1 Synth still has some of the highest zinc levels for our solid lifter cars on the market for an "off the shelf" oil. Most of the places around here don't carry Brad P.'s oil so the M1 is a good choice for me.
Happy motoring.
Junebug
Jan 18 2017, 01:29 PM
Brad Penn Amazon 6.99 qt buy the case and free shipping if prime. comes in 3 days. You'll notice the difference immediately.I know I did.
930cabman
Oct 9 2021, 04:44 PM
Fired up a partially repaired /4 today with an oil pressure gauge. It's running a steady 60psi cold at 1500 - 2000 rpms. Castrol 20w50. Should I be concerned?
emerygt350
Oct 9 2021, 06:22 PM
Nope. Perfectly normal.
