rich 918-S,
I had those same rims, little oval washers on my Nova
(aneamic 307 w/3 on the tree)
Right now my machine shop is a disaster, I'm still building my workshop, all I need to do is insulate and sheetrock 2 more walls, however, the biggest problem is that my Bridgeport is broke, my smaller benchtop mill is broke and my lathe won't work for this type of mods. I've got connections in "real" shops that make me killer deals on my personal jobs, it's just a time issue again with them.
Structually, i think the re-drilling of the hubs/flanges is fine since we have never heard of the 5-lug guys haveing problems doing this to the front or the rear.
However, maybe it's piece of mind, I don't need distractions going into corner 1 at Thunderhill pushing 110 and worring about my re-drilled front hubs
Mark,
Hubs are done, rims and tires mounted on car (0 miles besides putting the car on the trailer and off), basicly I buggered up a set of rear rotors, nothing too big of deal, get new rotors, do them correctly and move on.
The front hubs need to be redone (I used old worn rotors) or, and this is what was going to get expensive;
install custom hats/rotors and calipers such as Coleman Racing or Wilwood, this is what I really wanted to do, right now, it's not the time for such grandious modifications.
Like I mentioned earlier, the idea has been signed off by a respected local Auto-X/time trial Tech, but I don't want to run into issues later on down the road. Someone with a daily driver/auto-x car could run these re-drilled parts and rims and never have any problems until it came time to replace the brakes, then new front hubs would have to be drilled/studded and the rear rotors would have to be drilled.
When our new billet front hubs w/vented 911/914-6 rotors (any bolt pattern you want within reason) is finally available, i might go back to the "odd" pattern, the rims are cheap enough so that it won't hurt too much.
I already swapped back to the original front hubs (parted out a car a few months ago and kept the suspension), the hardest and expensive part will be redoing the rear flanges.
Who knows, if I cannot sell my 4x100 rims and tires, I might "have" to use them down the road
I test fit my 4x130 16x9's last night.....too bad I'd have to pull out the fenders.....besides, i think 9's are overkill on street car with a semi-stock motor
