I know someone who's got a 74 1.8 for sale and he wants me to make an offer on it. Its a bit tricky, because it has some good points and some bad points... Here's the good news first.
-original color (light blue) and seemingly original paint
-rubber is excellent all around
-body is very straight
-things close nicely, meet up nicely, etc.
-interior is clean (no holes in door panels, original handles on stuff)
-basically an unmolested car with original engine and no hacks on anything
-clear title, etc.
-in very nice shape from the outside and most of the inside.
Bad news:
-rear trunk area rusted, (some small holes, definitely needs replacement)
-battery tray gone, hole in wheel well, about 3 inches square
(although it looks like the rust stopped there, but I need to check it a bit closer to make certain of that)
-underside of car has some rust. Hard to say if its surface rust or not. the inside floor of the car is clean, the area behind the pedal cluster is clean, front trunk arear is clean except the lip where the rubber seal is on the very front (half of it)
So.... Assuming that the battery tray area rust is restricted to that area, (I'll try and scrape away some paint to verify this) and seeing as there is not any other structural rust, (longitudinals look good, suspension mounts are great)
what is this car worth? I've been told to make an offer...
The things I like about it most are that its basically original, and no one has patched things up or fixed things in cheap or crappy ways. THe things I don't like about it are obvious
-Tony
