skline
May 11 2004, 07:14 PM
Does anyone here know what the colors are of the wires for the coil and which terminal they go on? I am having a brain fart and cant figure it out. Help!
skline
May 11 2004, 07:30 PM
Maybe someone could walk out to their car and take a look. That wont take long. I just need to know which wire goes where. Anyone?
Levi
May 11 2004, 08:22 PM
Well shit what a bunch of lazy fucks..
I'm going out NOW...
Levi
May 11 2004, 08:29 PM
oh sure... I got my hands dirty again
Black = +
Green & Tan? = -
skline
May 11 2004, 08:35 PM
Thanks Levi, unfortunatly, that didnt help much, I have a black with blue stripe, black with a red stripe, and a green from the distributor. It has carbs on it.
Levi
May 11 2004, 08:45 PM
QUOTE(skline @ May 11 2004, 06:35 PM)
Scott,
I looked at 2 of my cars, the 74 1.8 FI car has 2 blacks going to the + side and green & white or tan (couldn't tell the real color) going to going to - side
The 74 2.0 is carbed and it had 1 black + and Green & tan to the -
I'm going out to the shop Now to check the blacks wires again and I'll also look at my 73 1.7 be right back
Levi
May 11 2004, 08:55 PM
Ok here is what I found.
Update on the neg. side Green (goes to dist.) the tan and also i found a black with a red stipe on it.
The pos. side has blacks with no stripes
skline
May 11 2004, 08:59 PM
Thanks, I will go try that
skline
May 11 2004, 09:08 PM
Well, its dark out now and I cant see shit, I think I will just wait till morning and try it again when I can see. Maybe I can get my neighbor to help me by turning it over so I can make sure I am getting spark. Cause it aint doing shit now. Thanks for your help.
Levi
May 11 2004, 09:46 PM
Let me know, I can do more checking if you need it...
maf914
May 12 2004, 07:00 AM
Man, this thread is like the battle of the boobs!
By the way, I'm talking about the avatars.
skline
May 12 2004, 08:56 AM
The bigger the better the tighter the sweater, thats what I have always heard. Still need some color codes and locations for a 2 liter with carbs. Anyone else with any ideas? Its a bosch coil. I have a thin black wire with a blue stripe, and thick black wire with a red stripe, and a green wire coming from the coil. The white or tan wire has never been hooked up. It ran before I just dont remember the combination.
Levi
May 12 2004, 09:01 AM
QUOTE(skline @ May 12 2004, 06:56 AM)
Ok, lets try this again
This is on my 2 liter W/carbs.
Green, white and black w/red go to the - Neg
Black, go to + Positive,......... It looks like a plain black wire to me
skline
May 12 2004, 09:05 AM
The thin wire loks all black till you look really close and it looks like a thin blue stripe on it. At first glance it looks all black, I will try that when I get back from work later this morning and see if it works. I have a white wire in the harness but it has never been hooked up to anything since the carb conversion. Does anyone know what it is for?
tat2dphreak
May 12 2004, 09:07 AM
http://www.pelicanparts.com/914/914_electr...al_diagrams.htmLevi is right, but I think on my '72, at least, it's a black wire with a purple stripe...
Levi
May 12 2004, 09:11 AM
QUOTE(skline @ May 12 2004, 07:05 AM)
I'll take a closer look when I go out to the shop
tat2dphreak
May 12 2004, 09:13 AM
QUOTE(skline @ May 12 2004, 09:05 AM)
you are right... all white wires went to FI, according to the wiring diagrams... that wire should NOT be hooked up
lapuwali
May 12 2004, 09:18 AM
The wire from the ignition points in the distributor needs to go to the - post on the coil. Should be easy enough to trace. ANY wire that carries switched +12 can go to the + post. That should be enough to get the car running.
Whatever wire is left over is probably the tach wire, and needs to go to the - post on the coil.
mike_the_man
May 12 2004, 09:19 AM
This is going by memory, but I'm pretty sure I'm right. The green wire that comes from the dizzy goes to the - terminal. The thin black wire with a blue? stripe goes to the - terminal, that drives the tach. The thick black wire goes to the positive terminal. It should have power when the key is on.
skline
May 12 2004, 09:29 AM
Well, I just couldnt wait till I got home from work and went out and hooked it up like that and it still didnt fire. So I started checking and found I had no fuel. So I went up and checked the fuel pump and verified the connections and then opened up the air cleaners and started getting gas. It fired right up. Runs good too. I am happy now. I think I will drive it around today for awhile. Thanks to all who assisted.
