2.2 liter ,side shifter , new clutch , release bearing and pressure plate .Alberta Car
can be daily driver , looking for a new project. Not perfect or the price would be
20k ,paint is original color Irish green new shift bushings hell hole is solid , battery
tray has never had to be replaced more pics avail for serious buyer . Located
in Ottawa Canada , Licensed and insured as a six cyl.
FOR SALE 1972 Porsche 914/6 ,
Green yellow , brown interior ,
$17500.00
5 speed ,78000 miles ( Conversion )
2.2 liter six cylinder ‘S cams ‘
Weber carbs ,K&N Air intake
Stainless steel brake lines
Cross drilled and vented brakes
5 bolt Wheels ,Fuchs Alloys 6 x 16”
Sway Bars front and rear
Side shift transmission and shift mechanism
19 mm 911 Master cylinder
M calipers front 3 inch spacing
Widened calipers rear with handbrake functional .
Vented 911, cross drilled rotors front and rear
New Brake pads front and rear
New Bilstein front inserts ( shocks )
New Ball joints
New rear shocks Boge and springs #140 lbs
New Speedo Cable and Angle Drive
New Carpets , Front Euro turn signal lenses
New Seat Belts ( and retractors )
New Fuel Pump ( relocated to front trunk )
Center Console with Gauges , clock , voltage . gas gauge
911 oil pressure /oil temp gauge
Porsche Oil tank
Porsche heat exchangers and exhaust
Electric Windshield washer pump
New tires 205/55 /60 x 16 Pirelli P6
Call Tom D’Amico 613-837-8553 or e-mail tdamico@aei.ca
Click to view attachmentClick to view attachment
