patssle
Apr 18 2011, 05:20 PM
Here's a pic that explains it pretty well. Can a tiny weld fix this, is it made of metal? Or any other suggestion on a fix?
Mike Bellis
Apr 18 2011, 05:31 PM
I think it is made of shitty pot metal. I do not know of a sucsessful weld.
Eric_Shea
Apr 18 2011, 06:00 PM
get a new one.
URY914
Apr 18 2011, 07:19 PM
Take the lock out and throw it away.
KELTY360
Apr 18 2011, 07:47 PM
Half broken is like half pregnant.
biggy72
Apr 18 2011, 11:20 PM
Is there anywhere to get new pins? I'm going to have to rebuild at least one outer handle and one inner, but we may have to do both sides before it's over.
I just bought a pair of handles for parts. I posted something about this yesterday, but didn't get much of a response. New handles are $125 a piece at pelican and a new flapper piece is $99 at Autoatlanta. I only paid $20 for the pair of handles because they have other issues, but the flappers looked to be in ok shape.
Montreal914
Apr 18 2011, 11:29 PM
Didn't someone recently post that he has a fix for handles? I thought I saw a picture where he was adding a piece on the backside
biggy72
Apr 18 2011, 11:32 PM
URY914 does for adding the rear tab back on, but it doesn't fix anything else. It's a pretty common problem though and it's definitely a nice way to fix them cheaply.
He has some pictures of fixed handles in his blog:
http://www.914world.com/bbs2/index.php?aut...blogid=237&
Drums66
Apr 19 2011, 11:18 AM
QUOTE(Eric_Shea @ Apr 18 2011, 05:00 PM)
get a new one.
.....Or a good used 1
(pot metal-get pissed trying to weld)
patssle
Apr 19 2011, 02:57 PM
Bummer! Oh well. New ones are expensive. I'll look for a used one. Or if anybody has one?
Eric_Shea
Apr 19 2011, 03:15 PM
I believe an M6 cap head fastener will work.
trojanhorsepower
Apr 19 2011, 03:42 PM
Mike Bellis
Apr 19 2011, 03:59 PM
QUOTE(trojanhorsepower @ Apr 19 2011, 02:42 PM)
They use it on trim or pieces that do not see any stress like the pivot on the door handle. I don't think it would be strung enough.
URY914
Apr 19 2011, 04:18 PM
Why do you need new pins? You can file the end off to get it apart and still reuse the pin. Also the AA replacement flappers are not the same size as stock unless he found a new supplier. You need to buy up broken OEM ones to get the good flappers.
MartyYeoman
Apr 20 2011, 01:18 PM
Been there, Fixed that.
Get new/better flapper, take the thing apart and repair it.
You'll save $$ over buying a new unit.
Marty
70-914nut
Apr 20 2011, 06:21 PM
i have a couple of handles
