QUOTE(porbmw @ Apr 20 2011, 09:58 AM)
I would quite like John's....altho I'm now not sure if it will work with a 2.7? re bar pressure numbering?
Depends a little on what's been done with the case. If it has 'the scavenge mod' you may be able to get away with a 5-Bar guage. 'The Scavenge Mod' began in 1983 and routed oil from the pressure bypass back to the input side of the pressure pump. If you have uprated the oil pump, 5-Bar may still be low... (One of the reasons Porsche went with the 5-Bar gauge in the first place is people freaked seeing (near-)zero oil pressure at idle...)
faint hope that the insurance company up here will allow it to be classified a collector IF it LOOKS like a GT...
IOW - you are hoping to reduce rates by convincing the insurance company you have a $500,000 look-alike performance car rather than what it is? Good luck with that, let us know how it goes... I know that one of the requirements for Classic (Antique? historic?) plates here in PA is that the car be in 'original appearing' condition. Don't know how fine a lens they apply to that, and if I can make an RS-look 911 be 'original appearing' if it looks like an original RS. We will see. But I'd think a 3000-unit production volume would be sufficient 'collector' criteria in your case...
Don't know if any of you have insurers that will give you a break in rates if appearances are correct.... that would mean I go with the old 911 gauge...
so there we are back to 'original what' - because a 914/6GT does not look like an original 914.6 ... I seriously doubt they're looking at dash guages, in any case...
The 10K tach....can they be made up from a parts bin.....if so, what parts.
Any Porsche tach will do, although you'd want one that works with whatever ignition you're using. The guage rebuilders renumber the face and recalibrate the electronics. At which point, the only issue is 'does it fit in the dash, and have the right indicator lights.' Hint - IIRC, even the GT's didn't have 10k tachs, but I could be wrong. They show up on EBay and specialised sites (like this one, and Pelican) from time to time. A 911 guage will not have the right indicator lights for a 914...
Question, do you need CHT gauge in a 6-cyl car?...
You don't _need_ a CHT or EGT is any car. They're nice, but pricey. The very best combo CHT/EGT guages are aircraft instruments, bring money. But they're also designed for in-flight tuning which they do all the time, and we don't. Even so, the probes are expensive, even if you go with only one per bank, and it's hard to make them meaningful if you want 6, even if you can find the panel space. It can be done.
