QUOTE(tomeric914 @ Apr 23 2011, 08:06 AM)
QUOTE(J P Stein @ Apr 19 2011, 11:33 AM)
BTW, use a filter with a high pressure by-pass. Mahle OC-54 is a good one.
This is kinda interesting. While doing a cross reference, I found that the OC-54 crossed to a Purolator L30260 which has a 20-25psi bypass. Purolator also makes a L30255 which has a 28-30psi bypass but it's shown as "Availability limited to existing inventory."
I prefer Baldwin industrial filters. The BT292 has a 30 psi bypass.
A long time ago a fella posted on Pelican that he rigged a pressure gauge on his scavenge side. He got peak pressures on a cold motor of 165 psi. He didn't give a hot pressure, unfortunately.
You can run any filter you want, I ran the OC-54.....the water is right over here, mr. horse..
