QUOTE(r_towle @ Apr 19 2011, 04:40 PM)
It will work perfectly fine if you have a Hemi or an SBC...
Stop drinking the coolaid.
In case anyone has any misconceptions, the algorithms used for "autotuning" do not care what kind of motor you are running. Adaptive learning is a much better decriptor than autotune as they work to optimize towards a set of predefined parameters, but cannot actually fully tune. In most cases the optimizations is only on the fuel side and seeks to reach a desired equivance (air-fuel) ratio. Off-the-shelf ECU's typically do not have the ability to optimize multiple parameters (ie: torque, fuel economy, and injector timing for equivalence ratio), simulatneously. Such processing either requires a pretty advanced goodness function or fuzzy logic capabilties. For that reason, real tuning for power and response is done by people.
Some ECU's autolearn quite well. I work with a group who has had great sucess with the ECU's and autolearn functions from the Australian company Adaptronic. I have also heard that MoTeC's autolearning functions are quite good.
Autolearn functions really come in handy when you want a somewhat safe base tune and either are driving alone or running your motor in somewhat steady state conditions on a dyno. They really can speed up the tuning process as any time that is normally spend on mundane map filling can instead be retasked to looking further into transients or timing.
Yep, I agree with the posted prices. Any good ECU is easily $1k+, and unless you have the fabrication capabilties to modify stock components (or the stock components work as-is), the remainder of the setup get very expensive very fast.
I will never own a carb again.
