914 Guru's... Please help, I replaced all my old fuel lines and relocated FI- fuel pump under gas tank. As PO had all wrong with filter on wrong side of pump etc. Everything was running great before, just doing restro and preventitive maint.
Well, turned the key after putting all together, no running fuel pump! Took a look at wiring at plug (MPC) and found bad splice on brown- ground wire. Repaired splice, should work right? wrong... still no juice to plug/wire.. I am starting to think that the fuel pump relay went-bad. All the relays look the same to me, Is there a fuse that I am overlooking?
All fuses in the panel are okay, Please advise...
I am stuck !! and WCC is coming soon! I will be eternally grateful...
