I recently discovered after filling the gas tank 3/4 full that there is a rust spot on the back side of the tank right where it has the potential to rub against the chassis.
Looks like the PO had removed the tank and painted it with some por 15 at one point. sadly it kept rusting from the inside and now it has a couple of pin holes.
Point being I guess have any of you guys repaired one of these tanks with gas tank epoxy or even fabricating a new section and welding it in place and then coating the inside of the tank?
Thanks for the advice guys!
