ruddyboys
May 14 2004, 03:58 PM
I was running the car checking the carbs (40IDf Webber) and noticed the right carb was leaking gas some were in the lower center. I just rebuilt them and they seemed fine. were is the mostlikely place they would leak from in that place?
lapuwali
May 14 2004, 04:33 PM
Accelerator pump cover. Also make sure they're not overflowing because of a stuck needle valve or float.
SpecialK
May 14 2004, 05:05 PM
I don't have the set of carbs any more, and I'm not near my IDF 44's, but I seem to remember there being pressed-in plugs at the base of the bowl. One of the plugs had a slow seep that the PO attempted to fix with some JB weld (attempted being the key word here). I ended up taking the carb apart, tapped the hole and screwed in a threaded plug (teflon tape to seal), never had another problem with it.
SpecialK
May 14 2004, 05:19 PM
REEEAAALL crappy pic of the carb, a where I believe the plug (that leaked) is located.
SpecialK
May 14 2004, 05:34 PM
Oops, I guess it'd help if I loaded the correct pic
SpecialK
May 14 2004, 05:35 PM
or somewhere around there.
