jsayre914
Apr 22 2011, 05:21 PM
Just about 30 min ago i got stuck in traffic on 83, there was an accident. I was in stop and go for about 10-15min. My car has been making a noise kinda like a compression ticking sound from the drivers side. But today it really started acting funny. The idle was dropping in and out in traffic, and when i went to move foreward each time... the car was shaking (violent) like it was running on 2 cylindrs. I kept revving it up to keep it smoothed out. When i got out of the jam, it seemed to come back once i got up to speed, but again when i hit a red light.
I am at work right now so i cant actually trouble shoot.
I did pull each wire of the plugs and it did not stumble on the drivers side rear plug. It did however stumble when i pulled the injector wire off the same cylnder
Valves were just adjusted last week.
I WILL MAKE IT TO THE EVENT !!any advise would be greatly appreaciated.
p.s.
Its raining
TheCabinetmaker
Apr 22 2011, 05:43 PM
If you still have points, check dwell and timng. High dwell( over 55) will make it run like crap.
sww914
Apr 22 2011, 05:44 PM
Sounds exactly like a bad spark plug wire to me.
jsayre914
Apr 22 2011, 05:47 PM
its got pertronix.
1.8 liter with L-jet
the wire had a nice arc from the wire to the engine tin when i pulled it off
mabey a fowled plug
Gint
Apr 22 2011, 07:19 PM
Could be a lot of things, but it sounds like ignition to me. Until you get in there you won't know. Check all of it when you get outa work. All the way to the plugs. And idle jets if carb'd, vacuum if FI.
r_towle
Apr 22 2011, 07:34 PM
make sure all your fuel injectors are plugged in tight...
They run like crap in low idle and run fine when revved up.
rich
jsayre914
Apr 22 2011, 08:47 PM
just made it home.
that ride sucked!
it feels like im driving a lawn tractor. No power at all. Whats worse than a 1.8 liter car....
a 3 cylinder 1.8 liter car
I am jackin it up now.
jsayre914
Apr 22 2011, 10:30 PM
Intake valve was almost 2 full turns to tight
i will now take it for a test drive
914itis
Apr 22 2011, 10:49 PM
jsayre914
Apr 22 2011, 11:02 PM
avidfanjpl
Apr 22 2011, 11:13 PM
I know all about badly adjusted valves.
My car ran like crap until I found cyl 4 badly adjusted by someone else.
It even sounded like a valve was sticking.
No more so-called expert type 4 tuners.
I did better myself.
J
euro911
Apr 23 2011, 01:06 AM
My wife's 1.7L ran 'OK' when we acquired it, found it had low compression in cyl# 4 and would hunt for idle until it warmed up. After a few months, I did a valve adjustment and the car really came to life (as far as 1.7's go) ... apparently cyl# 4 intake had been adjusted too tight, couldn't even fit a gauge in there
Glad to see you fixed
your problem
tomeric914
Apr 23 2011, 09:31 AM
Glad you found the problem and fixed it
QUOTE(jsayre914 @ Apr 22 2011, 07:21 PM)
This is always an easy one to spot. Car ran great, valves adjusted, runs great cold, now won't idle/run when hot. One or many valves adjusted too tight.
jsayre914
Apr 25 2011, 09:31 PM
Car ran great on the way home from hershey. I then drove 100 more miles with no problem. then i took it to work today, very fast
parked it.
got in tonight, no problems... 50 miles to my exit.... then car is shaking again SHAKING. It does not want the idle to go below 3500 rpm, it has no power and if the idle does drop below 3500 my whole car is shaking like running on 2 cylenders again.
i am pretty sure its time for a quick engine drop, pull that head
I just want to drive it!
p.s. I am totally ready to build my 2056 from the original engine.
r_towle
Apr 26 2011, 03:54 PM
check the adjustment again.
Two things....did you tighten all the nuts properly and are they still tight.
AND
did the measurement change since you did the adjustment?
If its the second one...you may have a head/seat issue.
Rich
914itis
Apr 26 2011, 04:03 PM
The sound system needs the other 2 cylenders to run. turn off the main switch for the amps..and you are good to go.
jsayre914
Apr 27 2011, 01:08 PM
I started to drop the engine last night, but then both of my girls started
all evening and this morning
I got about 3 hours sleep. If everyone is feeling better tonight I will continue.
in about 1 hour I got this far
car jacked up
wheels off
cvs off
shift linkage unhooked
muffler/heats off
throttle cable off
speedo cable off
clutch cable off
fuelpump lead unhooked
voltage regu lead unhooked
engine harness unhooked
batteries unhooked
pretty sure all i have left is...
ground strap
fuel lines
unbolt and go
Next question, what exactly should i be looking for on the head/ or valves.
(dont worry I will post pics)
jsayre914
Apr 27 2011, 01:10 PM
QUOTE(ppetion @ Apr 26 2011, 06:03 PM)
VaccaRabite
Apr 27 2011, 01:52 PM
You got a lot done in an hour. All that usually takes me an afternoon. I work slow.
Zach
Eric_Shea
Apr 27 2011, 02:13 PM
The valve seat you dropped.
r_towle
Apr 27 2011, 02:30 PM
if you are planning to remove the heads...its obvious if you dropped a seat.
If you want to check from just the valve covers...look for a valve height that is different...
Rich
jsayre914
Apr 27 2011, 03:13 PM
QUOTE(Eric_Shea @ Apr 27 2011, 04:13 PM)
read carefully my friend
i have dropped a seat before and the adjustment got really really loose.
my adjustmernt on intake cylender # 1 has gotten tighter and tighter at least 3 times in the last 20 days. Chris had said somthing a bout the possibilty of a valve stretching??
i have no idea
r_towle
Apr 27 2011, 03:56 PM
a seat that is getting beat into the head would also do this.
That is why I asked...what are you planning...
Gonna take the heads off or try to diagnose this via the valve covers.
Both can be done...
Rich
jsayre914
Apr 27 2011, 04:22 PM
i am pulling the head either tonight or tommorow depending on kids. The head was redone 6k miles ago with new seats valves springs etc etc. I need to know what the hell happened?
Dr Evil
Apr 27 2011, 06:21 PM
jsayre914
May 10 2011, 10:19 AM
Looks like my intake seat has been hammerd inward just as you guys thought.
Take a look.
the head is on its way back to rimco, it has only been 6k miles since it was done. they said they would fix it for me.
your thoughts are welcome.
Click to view attachmentClick to view attachmentClick to view attachment
jsayre914
May 10 2011, 10:20 AM
jsayre914
May 10 2011, 10:22 AM
VaccaRabite
May 10 2011, 10:33 AM
I see head leaks too. You really won't like the probable cause.
Zach
jsayre914
May 10 2011, 11:09 AM
QUOTE(Vacca Rabite @ May 10 2011, 12:33 PM)
Zach
jsayre914
May 10 2011, 11:48 AM
I just checked the old thread.... YUP its the exact same seat that started this mess
Last year
Click to view attachmentToday
type47
May 10 2011, 02:27 PM
QUOTE(Vacca Rabite @ May 10 2011, 08:33 AM)
Cap'n Krusty
May 10 2011, 05:16 PM
I have to repeat myself once again. There are good reasons I don't use or recommend Rimco. 'Nuf said.
The Cap'n
scotty b
May 10 2011, 05:18 PM
Joe, my machinist down here is really good and used to own a shop building type 1 and type 4 engines in the 70-80's. RIMJOb....errrrrrr RIMCO should make good BUT, Worst case, give them to me. Danny isn't cheap, But he is damn good and a damn anal machinist. He is the ONLY guy in town I trust to do aircooled engine machining
jsayre914
May 10 2011, 05:37 PM
so what is the verdict?
Rimco did a pisspoor job
the head is already in the mail and they said they would fix it. Dont worry, I learned my lesson, but I have already paid this job and they need to fix it.
I always know how to pick em
saigon71
May 10 2011, 06:53 PM
Bummer on that valve seat Joe, but at least Rimco is going to fix you up. Still sucks that you had to go through all this grief though. Do you keep the batteries charged and run the stereo once in a while when the engine is out?
jsayre914
May 10 2011, 07:19 PM
QUOTE(saigon71 @ May 10 2011, 08:53 PM)
NO
914itis
May 10 2011, 08:48 PM
Why r we blaming rimco? it'scaused by vibration from ........................the ......................................
jsayre914
May 16 2011, 03:15 PM
So......
Rimco recieved my head on Thurs 5/12/11. I spoke to patrick 11:00 am who said he would check with the machinest and call me back. No problem
4:00 I call back and the machinest says i have to pay to reweld the seat, no warrentys. offers me 15 % discount and red VIP tag to get it done the next day.
I say OK
Friday May 13th 3:00 (is it done??)
Nope
It will be done Monday
Monday May 16 12:00 talk to patrick, if it is done by 3 it can ship today
Monday May 16 1 hour before 3.... Patrick is out to lunch. Is there anybody eles that could check on my Head? Please Hold...
Sir, it dosnt look like they started it yet, I can have Patrick give you a call when he gets back from lunch.
jsayre914
May 16 2011, 04:05 PM
Just called me back 6pm May 16 two thousand and eleven
Tommorow for Sure.
saigon71
May 16 2011, 04:23 PM
Man, they are giving you a good "rimming."
Let me know if you need a hand with anything. We are only about 20 miles apart or so.
jsayre914
May 16 2011, 05:18 PM
QUOTE(saigon71 @ May 16 2011, 06:23 PM)
Hey thanks.
do you think you could pull my rockers, cut out the rust reweld and repaint the longs. If you still have time i need the rocker repainted too.
Joseph
type47
May 16 2011, 05:47 PM
You need to surf more throughly, you missed mepsteins offer
http://www.914world.com/bbs2/index.php?showtopic=125841get your car running before you get the head back
saigon71
May 16 2011, 06:13 PM
QUOTE(jsayre914 @ May 16 2011, 07:18 PM)
Hey thanks.
Joseph
Let me finish the one that has been on jackstands in my garage for two years first.
Give me a shout if you want a hand with the engine work to get that thing back on the road where it belongs!
jsayre914
May 18 2011, 10:38 AM
Your gonna love this shit
I got the head today!!!!
As I am typing this, I have a excavator, 2 dumptrucks, 6 guys and a buch of various heavy equipment removing my driveway. Not just the driveway, but a good foot under it, so they can fill with rocks etc. There is a 1 foot drop from the lip of my garage down to nothingness.
Did I mention it was pouring rain...
for three more days...
They cannot even finish the job until the weather cooperates. Dont worry... I planed ahaed and moved the teener onto the street a few days ago. (I pulled it with the family car and a rope) but....
the engine is still in the garage
jsayre914
May 18 2011, 10:51 AM
This might help you understand.
