Andyrew
May 15 2004, 03:21 PM
Ok, Im thinking that I should get a flat piece of plexiglass and cut it the same as my drivers and pass window. Maybe even taking out the mechalical mechanism and using some velcro and some other things to take out some weight.
Does this seem like a good idea?
Or a bad idea..
This will be a street car...
Just thinking aloud.
Andrew
Levi
May 15 2004, 03:24 PM
Yup, Bad Idea all right..
Your trying to save money aren't you??
I would bet someone here has a window that they will give you a deal on.
machina
May 15 2004, 03:50 PM
I cut all my windows from lexan. lexan is stonger and will not shatter like plexiglass.
It scratches very easily. I made the side windows using the glass part as a template and then attached an aluminum channel at the bottom to hold it in place.
Really just use the side windows for trailering and when I wash the car, otherwise I leave them out.
Mine is race car only. Don't think it would be good idea for the street.
dr
seanery
May 15 2004, 03:55 PM
bad, well, horrible idea for a street car. They scratch like you've never seen.
dan10101
May 15 2004, 04:38 PM
I was just wonderin...
Im sure I can get a window from a friend for cheap (since they arnt very much anyways..)
Thanks for the advice, I was Jus dreamin....
Andrew
campbellcj
May 15 2004, 05:50 PM
You definitely DON'T want to use acrylic or "plexiglass". It not only cracks and shatters way too easily, it is also (apparently) super duper toxic and nasty in the unfortunate event of a fire. No race orgs will allow it for those reasons.
So IFF you want to do the lightweight window thing, definitely use polycarbonate, of which GE's Lexan is the biggest brand name. There are different flavors and also coated and uncoated varieties. I just put in a Lexan rear window but it would not be advisable for (moving) door windows due to the scratch factor.
VegasRacer
May 15 2004, 06:18 PM
Andyrew - Your car is a 73, right? I have a nice pair of tinted windows from my 74 that will work. I can deliver them to you at the WCC if you are interested (and can wait that long). Make me an offer. (The price in the AA catalog is $220 each)
Andyrew
May 15 2004, 07:57 PM
Thats all right, I have a friend with 5 parts cars, Im certain I can find one. But if not, I'll keep you in mind.
Thanks all for the informative writups..
When i said plexiglass, I was using that as a general type.. (like Coke, or kleenex)
If indeedy I want to get light weight glass I'll go with lexan.
Andrew
morph
May 15 2004, 11:02 PM
these are a dime a dozen, if all else fails, we have a bunch.
SLITS
May 16 2004, 08:44 AM
Obviously not old enough to remember the plastic sliding side windows/curtains of the early British cars - (need a smiley with a white cane & dark glasses to put in here).
