Opps, I should have thought that one thru before I asked. Anyone have pictures of their setup?
Mike
QUOTE(Dave_Darling @ Apr 23 2011, 08:38 PM)
Nope. The sender for the light is a spring-loaded switch. It is either disconnected (light out), or it is grounded (light on). The sender for the gauge has varying resistance depending on the pressure.
You can get a dual sender, but it is larger than stock and doesn't fit well in the stock location. That's where the relocation kit (AKA a grease-gun hose plus a couple of fittings plus a metal bracket) comes in handy. You need to run another wire for the gauge signal, unless you use the wire from the light's sender--in which case you lose the light.
--DD
