I did a lengthy search and found no info.
As the title states the signals won't flash when the fuse panel is screwed down.
When its hanging it works fine. If I ground the fuse panel frame they no longer flash.
It is all OEM and not been touched really.
The wiring on the whole car is very original.
All bulbs light if you put on the signal switch, but do not flash.
E flashers do the same. All bulbs come on but don't flash.
If you leave the panel ungrounded all works normally?
All wires to panel look good and none are touching the panel.
All fuses are good and rotated for connection. Relay has been replaced.
Any Ideas? Thanks.
