QUOTE(ChrisNPDrider @ May 27 2011, 12:40 PM)
QUOTE(jtg @ May 27 2011, 06:35 AM)
Here's info on mine. Easy to convert, way too much fun!
http://www.evalbum.com/3439WOW, those Li-polymer batteries are pretty big. Did you consider trying to squeeze them in where the fuel tank used to be? Can you share how much $$$ the batteries cost total? Nice look on the all-black Riviera wheels
Chris, you should see what a lead acid electric 914 looks like.
By volume, the LiFePO4 batteries have more than twice the rated capacity compared to lead acid batteries, flooded or AGM. When you factor in the Peukert's Effect (reduced battery capacity under high amp loads) the Lithium batteries will carry you more than 120% farther for L/A batteries that takes up the same amount of space and weigh more.
LiFePO4 cells work out to be somewhere around $0.45/Wh of rated capacity, so the 28kWh battery pack in JTG's car would cost a little more than $12,000 today. But you get a 914 that can travel more than 100 miles on a single charge, better than the 70 mile (100 mile under optimal conditions) range of a $32,000 Nissan Leaf. The 914 will get to 60mph two seconds quicker than a Leaf.
So really, the electric 914 is a very viable alternative today.
PS. I worked on a couple of L/A 914's more than 15 years ago. I recently bought an electric driveline (Warp 9 motor, etc.) to convert another 914 in the near future. I got re-interested when I converted my 30' sailboat to electric with LiFePO4 batteries over the last year.
