QUOTE(ruddyboys @ May 17 2004, 10:06 AM)
Then I just got clicking from the starter. what the f*-#k did I do the car now?
The clicking usually means your battery is not at full charge and is likely very discharged. You need to charge the battery more. This has nothing to do with the fuel. What type of battery is it?
Next time if the car doesn't start after 20, 30 seconds of cranking, it isn't going to start. Figure out what's wrong and save the battery.
Once you get the battery fully charged, put more than 1 gallon of fuel in the tank.
Always avoid running low on fuel. In old gas tanks, when really low on fuel, the sloshing around of the fuel stirs up sediment at the bottom of the tank which is then sucked into the fuel filter and could cause it to clog.
A curious question: why were you so low on fuel?
I don't let my fuel tank get less than 1/2 full before refueling. These 40+ year old cars are hard enough to keep running and rolling the dice to see how low in fuel you can run is just asking for problems. Sorry for the rant. Good luck.
