Full Version: Installing Bearings and Hubs
Eric_Shea
After Saturday’s bushings install came Sunday’s bearing install. The factory manual can be quite vague on most subjects; lessons that become clear only after doing it so… hopefully this can clear things up a bit regarding installing rear bearings:
Step 1 – If you haven’t taken out your old bearings then you’ll want to do that. If the hub is in then you’ll need to drive it out of the control arm. This varies from a “light tap” to a “full blown slam”. You will ruin your old bearing but… that’s what we’re doing here. Find a suitable drift. Porsche calls it a P297a (better known as a suitable drift). I use an old 911 rear torsion bar. Once the hub is out you’ll need to drive out the bearing. Again, a vague reference to a “suitable thrust piece” to drive it out. After the hub is out you’ll see the lip on the backside of the bearing. Use a hardened punch and slowly tap out the bearing moving the punch from 9:00 to 3:00 to 12:00 to 6:00… you get the picture. Slowly so you don’t lodge it sideways in the bearing pocket and damage the control arm. Make sure the punch is resting on the bearing edge and not scoring the pocket surface. Save an old bearing housing…
Eric_Shea
Step 2 – Freeze your bearings. Do this as soon as you get them so they’ll be ready to go once you have prepped the control arm. This really does help. The tolerances are extremely tight. The cold bearing going in the room temperature housing give you the advantage.
Eric_Shea
Step 3 – Prep the arm. I like to lightly rub some 600 grit wet-dry in the bearing pocket just to feel for burs and to clean anything up. Don’t wrench on it just clean it up.
Eric_Shea
Step 4 – Install your now frozen bearings. I’ve seen these range from a virtual “drop in” fit to a “press in” fit. Porsche says use “special tool P302”. P302 is described as a ”thrust piece”. My “thrust piece” is an old bearing housing. I use a piece of flat steel on top of the old bearing and lightly tap the new bearing in. You must make sure the bearing is going in straight, if it goes in at an angle you’ll ruin the bearing and possibly the control arm. Be patient and tap lightly. As the bearing gets further down in the pocket you can begin to assert more force. Some may need to be pressed in the last few millimeter’s.
Eric_Shea
Step 5 – Once the bearings are in, install the bearing caps. Torque the bolts to 18-ft lbs.
Eric_Shea
Step 6 – Now it’s the time to reinstall the hub. Porsche says use the P298b assemble fixture. Most searches on the site give the answer to this factory tool dilemma. Use the stub axle. Slide the stub axle through the bearing from the backside and slip the hub over top it. Use the castle nut “upside down” to grab the first few threads on the stub axle. Once you get it started you can turn the castle nut over and finish the job. I only had 914-6 stub axles lying around and this set of control arms is for a regular 914 stub axle. I built a tool to draw the hub into the bearing. This consisted of a threaded rod and a few nuts and suitable sockets and washers. The main thing when performing this step is getting the hub in “straight” just as we did the bearings. You don’t want the hub pulled in at any exaggerated angle. Slowly crank it in.
You’re done. Put’em back on and enjoy the ride.
Eric_Shea
Getting started...
Eric_Shea
Getting closer...
Eric_Shea
Hub drawn in...
Eric_Shea
The install tool...
william harris
smilie_pokal.gif Go directly to the Classics threads! At this pace I will throw the Haynes manual into the trash. It tells you almost nothing. Thanks for such detailed instructions and great pictures. beer.gif
Eric_Shea
Right on Chief! Glad it could help. I was wondering if you were going this route as well...
tat2dphreak
Targa
Very clean Eric! I only have one question: When do you start pouring the vodka? confused24.gif
watsonrx13
A fantastic and comprehensive article.
Thanks for the effort of the documentation and the pics. I know personally how much longer it takes working on the car when you have to stop to take a pic. I'm working on 3 914's and completely documention my trials and tribulations of each.
This is the reason this BBS will succeed, the knowledgable people, such as yourself, taking the time to provide all of us with correct way to fix and or improve the 914s.
Eric_Shea
And... you're insane just like the rest of us. w00t.gif I've been watching your metalwork. Very nice! Here's to ya beer.gif I can't wait until you get that puppy painted.
Taking pics is becoming second nature. I'm our PCA regions newsletter editor and as Rich Herzog and other editors out there will attest: if you don't get the editorial no one will!!
Glad to help...
seanery
Great Job Eric!
I plan on printing this thread out to have with me when I do mine! smilie_pokal.gif
John2kx
Eric,
Great job on the procedure you used. Exactly how I did it with one exception. I froze the hub and allowed bearings to reach room temperature (actually overnight) before pressing frozen hub through bearing. Used a similar tool and found it real easy to drive home.
John
Eric_Shea
seanery
let me get this straight:
1. freeze bearing & hub
2. install bearing
3. let bearing come to temp
4. install frozen hub into ambient temp bearing race
does that go with what's been shown here?
Jeffs9146
I used a shop light to raise the temp of the Bearing before installing the frozen hub!
Jeff
415PB
Great job Eric. Thanks
ThinAir
Is there any of this that is different for those of us with 4 bolt wheels & hubs?
David_S
One of the things we do at work where we have really tight fits, like these bearings, is to freeze them and then pack them in dry ice for a couple of hours. Freezer gets them cold, but dry ice gets them colder !!!! Only thing is....you have to be really quick!!!!!
David S
SpecialK
QUOTE(ErnieDV @ May 17 2004, 09:39 PM)
Same procedure for us 4 bolters/bangers;)
ber914
Can this be done with the control arm on the car or must it be removed first?
Robert
John2kx
QUOTE(seanery @ May 17 2004, 03:43 PM)
2. install bearing
You've got it. That is the procedure.
Other: Control arm does not have to be removed and is actually easier when mounted to car.
John
Eric_Shea
HalfMoon
Hmmm...
I was just speaking with Glenn at Pelican as I'm ordering the FAG bearings for this job today and he cautioned me to use something to support the bearing while pressing the hub into place after installing them in the training arm. He warned that without doing this it's very possible to ruin/seperate the bearing.
Any thoughts on this?
D
Chris H.
Eric has some nice videos on his site...one shows how to properly install the rear hub...check it out:
Link
HalfMoon
Here's some images of the tool for that support while installing a hub
https://www.google.com/search?site=imghp&am...spx%3B768%3B512
QUOTE(Chris H. @ Jan 2 2014, 03:34 PM) *
Link
HalfMoon
Valuable link by the way.
TY
D
Link
Eric_Shea
QUOTE(HalfMoon @ Jan 2 2014, 01:26 PM) *
Hmmm...
D
This is a really old thread... here's what I recommend:
https://www.youtube.com/watch?v=T6CxhlpOvng
HalfMoon
Actually I think Glenn was referring to the dangers in the hub install and the need for support on the bearing. Beautifully explained in your video here:
https://www.youtube.com/watch?v=FDZv0j85Ybc
jfort
Thanks, Eric. If I ever have to do this job, I'll know where to look.
HalfMoon
Btw, do I recall a thread that stated what tools would be needed to do this job (specifically the wrenches required for the castle nut, and the trailing arm shafts? Farily certain I don't have any of those sockets/wrenches so I'll need to make a few tool purchases for this project.
And as I remember from Erics vid, a 1 13/16's" socket is needed to make the special tool for the hub install.
Anyone know that thread offhand or know the socket and wrench sizes?
Tanxs!
02loftsmoor
this is good information, the tricks that make it easier,, printed and saved . thank you
