I'm just toying with the idea...
with T4 main bearings in such short supply... by time I crack my motor open to have a lookie next year I hope there will still be some availability.
The motor ran fine when I pulled it a couple months ago.. I didnt do a compression test ( DOH! ) but the main problem it has is both exhaust studs are pulled on one cylinder and some DAPO welded the friggin heat exchanger to the head... GRRRR
So once I have my parts car stripped and I have room to put the engine up on a stand I'll pull the head and try to fix this mess... and welll... since I'm in there.. (divert wifes attention away ) maybe rebuild it to a 2056 or 2270.
If the main bearings are a PITA to aquire, I may just work on stuffing a 6 into it. I just dont feel like running an oil cooler up to the front. Meh... its all a pipe dream right now untill next year ..
