QUOTE(Philip W. @ May 18 2011, 11:01 AM)
QUOTE(Root_Werks @ May 17 2011, 04:32 PM)
D-Jet has some of the worst electrical plug/connectors there is on a vibrating engine. Once the little rubber boots dry up, they literally vibrate and fall out.
Check the plug for the FI trigger points at the dist. It may have come loose.
As others have mentioned, pull the trigger points and replace them, not cheap, but they do wear and cause issues in pairs of cylinders.
Thanks for the suggestions- plug is good, - I have seen your thread from the L-jet installation on yours, and saw you made some changes with dizzy etc. How long do the injector trigger points last, because i took an look, they look new, i put them in 18 months ago and they only have about 4000miles on them, seems they should be still good- yes they are expensive-compared to the other t.p.'s.
- i took the distributor out, changed out the points and the vacuum advance, rotor, etc, still no change,- just got the condensor so tonight i will switch that out as well. but anyway neither the points or the t.p. points seem to have any wear or corrosion at all.
-also going to replace the fuel filter tonight as well,
-How do you like the petronix?- i have one but have not put it in, - wanted to try to figure out what the problem is first, then give that a shot.
FYI- last year i put all new injectors, MPS, wires, points, plugs, fuel lines, vacuum, etc. - and 2 weeks ago running and idle great having just had valves set and full tune up and timing,dwell etc right on- 34 mpg on last 2 tanks(driving to work- 45-mph some stops) so thats why it seems so
-also tested the CHT - is not the problem
**UPDATE**- Running!- and here's what it was.---(drum rollxxxxxx)
Points and coil- not fi points,
Initially i installed the in-line fuel pressure gauge and new regulator- because i had one and needed to know if pressure was set correctly, - blew out some lines, put some fuel tx in tank etc new filter-- still did not run.
-changed out the plug wires, pulled the plugs, checked, gapped etc. -
- had pulled distributor, cleaned and reset points, changed the condensor, still no go.
-i had ordered an electronic module(hotspark) and the matching proper ohm coil
so when that came i installed and wired the module with the new coil, and ---
immediately started- so it was electronic not fuel,
runs very smooth right now, but was not able to dial in the timing as of yet, and i'm not sure i have the hoses all hooked up correctly right now.-(vacuum advance and retard). idling at 1400, if i go lower, it surges - i had that problem before and did not get it set until we did the valves and then timing,then the surge went away and had perfect idle speed)
so i know i have to set it at 3500rpm but could not get timed right for some reason- moving the distributor would not get it lined up at that RPM- yes hoses were disconnected at the time.
recheck valves? what else?- timing mark is correct
any suggestions on that? otherwise very close and atleast it is running, will see how long the hotspark lasts.
phil
