QUOTE(jaxdream @ May 1 2011, 07:44 AM)
QUOTE(TCAlien @ Apr 30 2011, 02:30 PM)
QUOTE(PRS914-6 @ Apr 29 2011, 06:21 PM)
Spacer...
Is there a reason you can't just use the 5mm wider bearing from the 911?
The wider bearing was used in the aluminum rear arm of the 911 , not the early steel arm which used the same size bearing as the 914 , that was designed to hold securely the wider bearing which is the problem with trying to use the wider bearing in the 914 arm - no real way to secure the bearing and have the entire bearing supported without modifing the arm to do so. It is cheaper to use the 914 bearing , spacer to accomplish the use of the SC hubcentric hub unless some one wants to go through the effort of modifing the 914 arm .
Jack / Jaxdream
This is PART of the answer why you can't simply use the wider 911 bearing.
The other part of the answer is that the 911 wider bearing is also larger in OD.
One would have to bore the trailing arms to accept the wider bearings, but there isn't sufficient space between the (4) retainer plate bolts to do this.
Back in the early 80s, someone (I believe Beach Boyz Racing, or George Vellios) made some castings that could be welded to 914 trailing arms that allowed use of the 911 larger and wider rear wheel bearings and also allowed 911 e-brakes. The trailing arm mods were to remove the 914 cast part and weld the new one in place. I wish someone still made those castings, but I haven't seen them in years. Unfortunately, I was far too young in the early 80s.
