ELLIOTT
Apr 30 2011, 02:34 PM
Ok so I happen to be under the 914 ( go figure) and notice that the thermostat wire is hanging down. My question is are the baffles open or closed at this time when the engine is cold and the wire disconnected ? In reattaching the wire do I rotate the bar and hook up the wire or leave the bar/rod in its current position and attach the wire?
thanks
Elliott
Krieger
Apr 30 2011, 03:07 PM
Rotate the lever on the bar (against the spring tension) then attatch the cable. As the motor warms up the thermostat lengthens and allows full flow. No wire attatched = full flow.
ELLIOTT
Apr 30 2011, 04:00 PM
Thanks, thats what I was thinking but had to read it .thanks again
