Elliot_Cannon
May 21 2004, 11:26 PM
Hi,
I put a much smaller steering wheel on my 73. It is not only smaller than the stock wheel but puts my hands closer to the dash. I keep hitting the wiper switch and starting the wipers on a dry windshield. My question is can the wiper switch be bent to a straiter shape? Or will bending it break it? Has anybody had this prob.? Any ideas? Thanks.
Cheers, Elliot
campbellcj
May 21 2004, 11:29 PM
Lame Horshack impression..."OH OH OH OH!"
Bradhole taught me a trick a few years ago; simply cut off the wiper lever to a "stub". If you are careful (I wasn't particularly) then you can round it and clean up the end so it looks stock...just shorter.
Problem solved, $0.
May 21 2004, 11:33 PM
you can also get a "spacer" for your adapter that will move the wheel further out ...
i have PLENTY of space between my 350 momo and the levers ...
Elliot_Cannon
May 21 2004, 11:34 PM
Now why the hell didn't I think of that.
I like it. Especially the $0 part. Thanks!
Cheers, Elliot
Elliot_Cannon
May 21 2004, 11:38 PM
Thanks Andy. Another good idea. I like the wheel further away from me to accomodate my simian like arms. ( I can see a hacksaw blade in my immediate future.)
As usual. Two great answers from this board in a matter of minutes.
Cheers, Elliot
campbellcj
May 22 2004, 12:34 AM
Yep my current wheel hub has tons of space between steering rim & levers; however, in track/autox conditions it is still possibly to hit the levers when frantically trying to keep the car going reasonably straight.
Then again, my car doesn't usually have wiper blades installed (it still has a motor), so nobody could tell if I accidentally hit the lever <_<
Curvie Roadlover
May 22 2004, 08:45 AM
FVD-USA sells a spacer that fits between a MOMO wheel and hub for about $20. It moves the wheel about .75" closer to you (away from the wiper lever). It's also offset a bit from center so I use it to make my steering wheel a little higher when pointing straight.
