Well I'm still stumped, Went through all the vacuum lines, Checked the plugs, cap rotor, points, wires.
When I started it up after putting everything back on, it still runs very bad, it cuts out all through the RPM range and the exhaust smells very rich, I unpluged the cold start valve but that made no difference.
The plugs were all sooted up so I'm pretty sure its getting to much fuel.
What do you think I should check next?
