QUOTE(Jake Raby @ May 3 2011, 09:39 PM)
We run stock studs to 11;1 CR with iron cylinders. Retain stock head torques and roll with the stock studs.
Not building anything too over the top. I am just so used to building Domestic engines and APR are a staple when building them. I have been trying to benchmark as much as I can from others builds and I have your DVD to guide. I just wanted to know because I would rather have overkill then not enough. So many time in the past I have built engines and it doesnt take long to find the weak point. So far I think that I have eliminated the weak points along with the replacement of everything minus blocks. I have H beam rods since I hear that the stockers can get weak. I replaced the valve seats. Stainless exhaust valves... and changed out the oil plugs with thread in. Any other weak points that I didnt mention that you may chime in on? I am really open to anything. I want the most reliable engine I can build.
Thanks,
Thomas
