Why is one better than the other? It all has to do with components. Bosch is not perfect by any means.
A Capacitive Discharge Ignition is just that. Some have cheap components, some don't.
Regardless of which one you decide to use, always carry a spare.
or
Buy a Crane Hyfire, MSD 6 or 6AL or whatever ... they all perform the same function as a Capacitor saturates much quicker than a coil.
Also, you do not use a coil ... it's a transformer. Point style ignitions use a coil that is fed 9 - 12 VDC (depending whether the coil is internally resisted or not). A lot of cars used an external resistor to drop 12V to 9V.
A CDI unit feeds the transformer 400 Volts. A "standard" coil won't like that voltage much.
Hell, I'll trade you a Bosch unit for the "Permadoom"..... they're all the same to me.
But then I am not a professional mechanic .... just a backyard, shadetree parts changer ...
Maybe the early Permadooms aren't that great ... I've run the silver one, blue one and I don't know if there are any other colors.
