TravisNeff
May 25 2004, 11:49 AM
I think my VR died and now my battery shows 18volts, what kind of damage am I looking at?
Currently I cannot start the car due to a Fuel pump circuit issue (unless the 18v has hosed up something)
SpecialK
May 25 2004, 12:18 PM
Unless I'm forgetting something, a 12v battery can't have an output of 18v <_< . A fully charged 12v automotive battery should have an output voltage of 12.7v or something close to that. I'd say that the meter/gauge that you're using is hosed. Buy a cheapo multimeter from Radio Shack and check it again.
TravisNeff
May 25 2004, 01:59 PM
My voltmeter hooked up to the + battery terminal shows 12v, but with a multimeter it shows 18v at the posts. Other checks of the wiring harness shows 18v as well.
davep
May 25 2004, 02:00 PM
How are you able to measure the 18 volts? You may fry the computer with a voltage like that.
Joe Bob
May 25 2004, 02:49 PM
Disconnect the battery....read it. Should be 12.5 volts. Reconnect it....12.5 volts......start the car, 12.5-13.0 at idle....2500 rpms 13.0-13.5ish.....anything over 14.0 is bad......
Allowing it to take an overcharge like that and the battery can explode.
TravisNeff
May 25 2004, 05:44 PM
all true checks were done with a DVM
tod914
May 25 2004, 11:18 PM
Mike,
what would over 14 indicate??
Mueller
May 26 2004, 12:01 AM
batteries can explode/leak if grossly overcharged, can you measure the "field" of the VR?
TravisNeff
May 26 2004, 01:06 PM
how do I do that?
tod914
May 26 2004, 06:25 PM
how do I do that?
inquiring minds would like to know. mine is getting so hot i can fry an egg on it.
