jeffdon
May 7 2011, 07:41 AM
arkitect
May 7 2011, 08:24 AM
No, but I like the looks of them...pinned and made of aluminum so they are light.
I picked up 4 jack stands the other day at an estate sale but they were the screw type and either aluminum or alloy for a outrageously cheap price of $5.
Dave
ConeDodger
May 7 2011, 09:23 AM
I have 4 Harbor Freight Aluminum jack stands in my 'track kit'. I have never had to use them or the aluminum "race jack" that I bought with them but my god they're gorgeous!
Katmanken
May 7 2011, 04:21 PM
Interesting comment in the ad. One guy liked the "small footprint". Smaller footprint means a more tippy jackstand. Long as they are used with that thought in mind they should be OK.
Ericv1
May 7 2011, 05:38 PM
QUOTE(kwales @ May 7 2011, 06:21 PM)
I have a pair that came with an aluminum jack that I bought from Home Depot. I've been using them for 3 years now. The base is actually about the same size as the jack stands that I purchased from Tractor Supply last year. I've never had any tipping problems.
Gint
May 7 2011, 06:38 PM
No, I don't have those, but I'd like to.
Elliot Cannon
May 7 2011, 07:54 PM
QUOTE(Gint @ May 7 2011, 05:38 PM)
If Mike trusts them, they have to be good.
ConeDodger
May 7 2011, 08:14 PM
QUOTE(Elliot Cannon @ May 7 2011, 05:54 PM)
WORD!!! Once you've had one fail, and a car land on your beak, you might have an opinion on jackstands!
avidfanjpl
May 7 2011, 09:10 PM
I have 2 of them and I love them. I use other blocks of wood and a jack 1/4" off of contact since I live in SoCal.
They are gorgeous, light and I put them under the front doughnuts, but I always have other things to catch the car in case we get a 7.4 or stronger.
I also spend as little time under the car as possible.
I want to drive the car, not cushion it!
John
McMark
May 8 2011, 10:56 AM
I have some BluePoint stands that are awefully similar looking. They don't go very high, but they work great when I use them. Never had any stability problems.
euro911
May 8 2011, 11:03 AM
I like aluminum stands as their light weight makes them good travel stands.
The aluminum ones I have have wide bases which I prefer, especially if needing to use them on a less than ideal (read - flat) surface.
For home/shop, the heavy duty ones are fine, don't need to be light weight.
The ones shown look nice and I like that they are pinned, but I don't like the small bases ...
McMark
May 8 2011, 01:40 PM
Consider that a jackstand base is only as stable as its
smallest flat sides. I just measured a set of 'small' clicky harbor freight jackstands and they're 6.5" from flat to flat. My BluePoints are 7" across. So the BluePoints are more stable.
The link above lists...
Base L x W (in.) 6 3/4 x 7 1/2
So the ones linked to above are also more stable (6.75") than the HF stands I measured.
StratPlayer
May 8 2011, 03:18 PM
Got a set for christmas, haven't taken them out of the box yet.
Tom_T
May 9 2011, 12:40 PM
I looked at them, but haven't bought because I have a set of 2 old school steel pin type wide framed square base stands which are pretty stable that I'd like to match with some garage sale types - since nobody apparently makes that type anymore.
Another option is the sets of 2 or 4 aluminum screw-type wide base stands which Camping World online sells for trailers for $22 & $45 respectively IIRC. Look online at their website.
