RJMII
May 8 2011, 06:45 PM
My build thread is in my signature.
Body: hell hole is fine. it needs vacuumed out and coated.
jack points are fine.
front trunk has a radiator in it and full of holes.
bumpers were back dated, and the front one has a hole in it with an aluminum grill for air flow
d-side front of the car has been hit, and has been repaired by someone that didn't know what they were doing. it looks okay with the trunk closed.
rear trunk has a BIG hole in it from where I took the sawzall to it to get the engine to fit.
suspension:
front is 911 SC, has 19mm m/c to match the bigger brakes.
rear has yellow konis and five lug hubs done by PMB
interior was redone, it's slightly apart right now
engine: (pulled, no longer in car)
current engine has a knock, and a turbo that needs a rebuild. it's a mitsubishi 6g75 with a BIG 16G turbo.
engine management is Megasquirt 2 using Ford EDIS 6 for spark distribution
Replacement engine (comes with) EDIT: partially installed now!
Twin turbo engine from a 95 mitsubishi 3000GT VR4
it should bolt in right where the other engine is sitting. It will require a little bit of different plumbin to switch from single turbo v6 to twin turbo V6.
RJMII
May 11 2011, 03:26 PM
I'll add more pictures when i get out of the hospital again.
chuckc
May 13 2011, 09:58 AM
QUOTE(RJMII @ May 11 2011, 05:26 PM)
If I lived closer I would be seriously tempted to sell mine and buy yours.
On a side note it's good to see someone that loves their wife like that!
good luck with the sell.
chuck
AgPete139
Sep 27 2011, 02:47 PM
I liked this build, too.
Pete
RJMII
May 27 2012, 12:50 PM
back on the market.
make an offer, you might be surprised.
chuckc
Jul 12 2012, 08:37 AM
did you get her running? this is the perfect rat sleeper.
