The Beast is For Sale
1974 Chassis
Body
Roger Sheridan standard body kit. Full clips front and rear.
Fiberglass front and rear deck lids.
Gutted doors.
Full custom roll cage.
60” GT Racing adjustable carbon fiber rear wing with uprights.
Paint Interior and Exterior is Grand Prix White.
Motor
Built by nationally known Porsche race motor builder Mat Lowrance (Reno).
2.7 Liter 6 cylinder with 9.5:1 compression and Haltech ECU and FI.
Runs on 91 octane.
Patrick Motorsports lightened flywheel and Centerforce clutch kit.
Rich Johnson center mount 914-6 engine mount.
Peterson 16 quart oil tank.
Remote oil cooler mounted in nose with sheet metal ducting.
Earl fittings used throughout.
Fire shield and/or thermo insulation on all cables or lines.
Exhaust
European Racing Headers 1 ¾” I.D.
(2) Smart Racing products Phase 9 mufflers.
(2) Dynomax Super Turbo mufflers for Laguna Seca sound restrictions.
Transaxle
901 5-speed with M-S-X gears.
Guard 80% ZF style LSD.
1st/reverse lockout
Suspension
Front and rear suspension pick-up points raised 2 inches in the car.
Roller bearings in front A-Arms and Rear trailing arms.
Ground Control 2-way adjustable coilovers front and rear.
Front spindles raised.
Spring rates Front: Eibach linear rate 325 lbs/in.
Spring rates Rear: Eibach linear rate 450 lbs/in.
Front AR bar = Smart Racing bar 27mm adjustable.
Rear AR bar = none.
Helper springs installed on all shocks.
Safety
Fuel Safe fuel cell with surge tank installed.
Cabin mount fire extinguisher.
(2) Sparco EVO 2 race seats (black).
(2) sets of Schroth 6 point safety harnesses.
Momo leather competition steering wheel.
Smart Racing Products quick release steering wheel hub.
Painless Wiring Electrical Cut-Of switch.
Brakes
1989 Carrera front calipers (front and rear).
Hawk Blue racing pads.
Cockpit adjustable brake bias valve.
Tire and Wheels
(4) HRE 3 piece mesh lightweight racing wheels size 16x10 with 5 ¾” backspacing.
Front tires = Hoosier R45A 22x10x16 bias ply slicks
Rear tires = Hoosier R45A 23.5x11.5x16 bias ply slicks
(4) Diamond Racing steel wheels size 16x10 with 5 ¼” backspacing.
Rear tires = Hoosier R45A 23.5x11.5x16 bias ply slicks.
Ground up build with new or rebuilt components.
This car has two track days to adjust the suspension, i.e., 2.5 hours on new motor.
We can arrange for PPI at Jerry Woods or another Porsche race car expert, of your choice, upon request.
$16,500 /o.b.o.
Bill Pickering
(408) 410-9005
wmhpickering AT yahoo DOT com
