QUOTE(914 shifter @ May 10 2011, 05:45 PM)
today my driver side outer door handle failed luckily i had the top off.
the door opens no problem with inside lever.do i need some cams ?
i have heard this is a common problem. any vendors or members have
these parts. then i have to figure out the install
It sounds like you need a door latch cam,,,,
http://www.pelicanparts.com/cgi-bin/ksearc...4-531-905-00-PHWow it's 14.55 now!
You need to:
1) roll your window all the way up
2) take off the door panel
3) get a 4mm or 5mm allen wrench (I can't remember size) or allen-socket with long extension to loosen the bolt holding the front of your outer door handle to the door.
4) loosen the 10mm nut on the back side of the outer door handle that you can see when you open the door
5) replace the plastic cam and re-install
-Robert
