Hey guys,
I have owned my 914 for about just 3 years. The car is stock and runs just fine, well much healthier than when I bought it. However, I never liked the shift feeling. It has slop regardless where the gear position is. I have replaced all worn and old parts in the shifting. Here is a list of what I've changed to new.
1. Cone set screws
2. Bushing - fire wall
3. Bushings - crown shaped @ console
4. Bushings - Shift coupler
5. Bushing - Ball socket @ shift console
6. Seal and O-ring - Shift arm at console
7. Reverse Lockout Plate
8. New tranny oil 80w-90
I have added a shim at the crown bushing since there is a little gap. I did not change the shifter because it did not look worn. Funny is, with the new Lockout plate, the shifter can go to reverse from 1st with no mechanical resistance when the engine is off. Is this normal?
After replacing above parts, slop in my hand had reduced well maybe 20% but it is still soppy even it's in the gear. So is the tranny due for rebuilt or am I missing something still?
Thanks,
kkid
