70 car that I just put the gas tank back in. I am missing the holder downer for the big square container that goes on top of the tank around the filler. go the screw on the pass side, there is a place for a screw on the drivers side but nothing to screw into on the tank. Vapor canister is good that was easy.
second item. yes it appears that the wiring for the driving lights it there. cut back all cable housing and let the water drain out. and found the whit/yellow wire knarled and chewed . But it is there. <_<
