I could email you from your site but I thought some others here may like to know this stuff too.
1. I know you were going to start offering T-IV parts, but that never really came around. Is that plan dead?
2. You are offering kits now, but I already have pistons/rings/cylinders and big valve heads. Would you do part of a kit? Say the crank, rods, bolts? It just doesn't make sense for me to buy the kit when I have these parts.
3. I've searched the STF for the "best" rod to use and I learned what NOT to use, (Scat- need to remove too much, Stock- too heavy) but can't find what TO use. What will work best? I know you were working with a rod manufacturer that was going to be your supplier when you were going to do the parts gig. Is your rod supplier a secert?
4. I know you have done a lot of development work with WEBCAM and have a lot of special grinds with them. Will they or you sell these grinds to me directly? Or should I just stick with the standard grinds the aircooled.net has?
As always thanks for the info and I don't mean or want to try to go around you to a supplier but just want to know the best means to get to the end result.
Paul
