Everything was going fine with the 2.0 Liter engine rebuild for the 2 wheeled type4. I had all the major engine components ready for the rebuild.
Then last weekend I mounted the crankshaft in the vise with rubber jaws.
Heated and installed the cam and distributor gears.
I left the crank vise while I took a break to eat dinner.
While sitting at the dinner table I heard a really loud "BONG...ONG....ONG! coming
from the garage.
The crank slipped out of the vise, did a 180 and hit the concrete garage floor.
Chip in concrete floor!
After the event I mounted the crank between centers and measured the center journal run out 0.002". I also put the crank in the case with the end bearings only and measured the run out 0.002".
I'm stuck trying to decide what to do? Buy a rebuilt crank? Try and fix this one?
Or just use it as is?
