So here is what's new, A fellow 914 guy,(Thanks Jeff), sent me a Air Flow Sensor (AFS) because my old AFS tested bad, I received it today and put it in, it starts it runs. ..After it gets all warmed up it runs like a top...it has good throttle response pulls good all through the RPM range..COOL..But here's the thing I'm puzzled about even though it's running great it hunts the idle between 200-800 RPM's until I remove the oil filler cap when I remove it, the idle smoothes out and sits at 1000 RPM's and the car seems to run perfect...What's up with that??
