QUOTE(Scott Carlberg @ May 29 2004, 02:41 PM)
I have over 230 reliable hp.
Scott,
I agree with what's been posted about 911 engines.
And I will never have the money to buy a 911 GT1
Unless I start playing the lottery and actually win.
If you do the work yourself its just the cost of valve cover gaskets, oil and filter.
Except for adjusting the valves and replacing the gaskets its no diferent than the maintenance on my Toyota.
Well except maybe twice the amount of oil.
But the Toyota's spark plugs cost twice as much as my Bosch plugs.
If you install a 993 3.6 you no longer have to adjust the valves and or change the gaskets.
The hassle with the 3.6 is the additional work to install and its a bitch to get to the lower plugs.
I think a 911 is more expensive to maintain than a 914-6 conversion.
There is more to go wrong with a 911's body and electricals than a 914-6.
What I mean by body issues is with a targa or cabriolet versus our simple removeable top.
You also have power steering, electric windows, locks etc. to maintain.
My own experience with 911 engine reliability dates back to 1986.
Back in 1986 I installed a 1974 2.7 liter six that had a top end overhaul.
I put 75,000 drunken abusive miles on this motor and was hitting the rev limiter every weekend.
This motor never broke down on me.
Four years ago I could tell the head studs were starting to come loose.
This is a common problem with 2.7's and stock head studs.
The cost of overhauling a 2.7 was more expensive than getting another engine from a wrecking yard.
So four years ago I bought a Euro 3.2 with 80k miles on it for $5500.00.
This motor puts out 231 hp with stock exhaust and catalytic converter.
I'm much older now (43) so I don't drink and drive anymore but I still beat the crap out of my cars.
So far I have driven this car for four years with no problems.
I am also more happy with the additional power and DME fuel injection versus the webers on the 2.7.
The 3.0, 3.2 and 3.6 are known to go well over 200k miles.
As mentioned there is some rare cases of 3.2's with valve guide wear.
Mine has almost new compression and no valve guide issues.
The advantage of the 3.2 and newer is you get the hydraulic chain tensioners.
But this is easy to add to a 3.0.
I would not recommend a 2.7 unless the engine has already been overhauled correctly with raceware head studs and other mods.
I feel the 3.2 is the best motor since its the least amount of hassle to put in.
You don't have to cut the 914-6 aftermarket engine tin to make it fit.
With the 3.6 you have to cut up the tin and its a bitch to get to the lower 6 spark plugs during maintenance.
The advantage of a boxster or 996 motor is obvious.
The motor will have all the latest updates and be much newer with less miles.
All we need is someone to make a kit and figure out all the problems.
I bought one of the first quick six mounts from MSDS back in 86.
We have come along way since then.
I now run a Richard Johnson mount so I can use my factory heat exchangers.
If someone figures out all the issues with installing a 986/996 motor in there car I might try that next instead of overhauling my motor or putting in a 993 engine.
For my next project it will be AC in my car.
This will allow me to to drive my car all year round!!
The heaters already come in handy.
Steve
