QUOTE(Dave_Darling @ May 12 2011, 11:07 PM)
L-jet + lean == vacuum leak, almost always.
--DD
L-Jet is crazy sensative to vacuum leaks. Even the valve covers are critical to get 100% sealed.
99% sealed on L-Jet will make it run incorrectly. Check everything, as others have said, replace hoses.
Also, the oil filler has to be 100% sealed, the cork gasket at the base has to be soft and 100% sealed.
I wouldn't adjust anything, just seal the system up.
