QUOTE(seanery @ May 29 2004, 06:02 AM)
I always thought Magnesium was the lighter of the two, but on Popular Hotrodding TV this morning they stated that Mag was heavier than AL.
well - there's always that unstated condition that goes something like "for equivalent strength..." (for the record, a pound of aluminum is just as heavy as a pound of magnesium ...)
so there's a few factors. density (weight per unit volume) is one of them. Mg is weaker than Al in several important areas we care about, especially in a wheel context (it is more brittle, less ductile, and lots more corrosion-sensitive). so a dimensionally identical Mg wheel will be lighter than an Al wheel - but it will also be weaker. by the time you add enough material to make it an equivalent strength, it's not only heavier, but larger...
the line on Mg engines cases was that they are strong - "for their weight." that's not the same as 'strong.'
