I did this modification to mine just last summer, I'll try to rememer to post photos in the next two days if possible! It has to be a compact spare in order to fit in the vertical position; I mounted mine on the drivers side to fit with the battery mount installed on the passenger side, only I replaced the leaky acid battery disaster with a dry cell Optima Red Top.
With the help of 2 friends, (who happen to have assorted metal scraps of all sorts on hand) I fabricated a mount out of very heavy steal, similar in apperance to the factory mount. The threaded portion is a 1/4" thick rectangle of steel tapped on a drill press, welded to two thinner pieces of steel to elevate it +/- 2" and then mounted the compact 5-lug 911 spare (back of wheel facing firewall) with an NOS Porsche spare tire hold down bolt & plate!
