theo
May 16 2011, 07:33 PM
I have a 1.7 with carbs. on Thursday I had the air filters off while I was cleaning them, anyway after cleaning I reinstalled them and took the car out and drove it several miles and everything ran perfect. I was out of town all weekend and when I started the car up for school this morning there was a loud knock that sounds like metal on metal so I immediately killed it. anyway I cant find where the noise is coming from and I am not going to start it up again. the only thing I can think of is that maybe something dropped down into the intake. anyway I am about half way to having the head off and decided to take a break and see if anyone has any input. Also, I removed the spark plugs and there is no sign that it had been struck.
r_towle
May 16 2011, 07:46 PM
Have you synced your carbs lately?
Did you possibly drop a screw or nut down the carb into the intake?
Rich
theo
May 16 2011, 08:00 PM
it has been a while since Ive synced them. they have seemed very smooth. and I have not touched any of the geometry in the last week. and I idk I was stupid, in a rush and didn’t bother to stuff a rag down, so its always a possibility. and can i pull the head off w/o taking the rockers off. just pull the pushrod tubes and rods out of the case side?
Mike Bellis
May 16 2011, 08:05 PM
I sucked a screw into my V8 one time. It was the loudest clank I ever heard. It forged the screw into my aluminum head. Pulled it out, new gaskets and drove it for many miles...
theo
May 16 2011, 08:14 PM
well. i am in the middle of a 2.0 build but its not done yet and i need a daily driver haha
TheCabinetmaker
May 16 2011, 08:20 PM
there are two bolts that are blocked by the rockers. The tubes also require removal of the rockers.
r_towle
QUOTE(theo @ May 16 2011, 10:00 PM)
Half day, pull motor, pull head...look.
Rich
theo
May 16 2011, 08:52 PM
yeah I've got the head separated from the cylinders and it dos look like there is one of those sheet metal tinnermans that the bolt for the air cleaner goes into :/ must have broke.
76-914
May 17 2011, 09:36 AM
QUOTE(r_towle @ May 16 2011, 07:20 PM)
Rich
That's right, Rich; rub it in. 1/2 day for you and a full day for the rest of us.
SGB
May 17 2011, 10:40 AM
dontcha love it. The weakest link will get you. Fuching screw.
stugray
May 17 2011, 10:52 AM
Yeah, when I broke down my webers all the way I couldnt believe how hard it was to get the screws out of the butterflys.
Then I realized they had blue loctite, and thought "Oh yeah, it would be very bad if one of those came loose" ;-)
How did you manage to get the head off with the engine still in the car?
Arent the engine tins in the way?
Stu
Drums66
May 17 2011, 11:47 AM
QUOTE(kg6dxn @ May 16 2011, 07:05 PM)
...If you catch it early.....this can be done!
(If that is what it is?)
SUNAB914
May 18 2011, 08:02 AM
Are you sure that one of the lifters just isn't sticking till it gets oiled up? My hydro lifters will do that if it hasn't been driven in awhile? Mile or so, and super quiet again. good luck.
theo
May 18 2011, 11:20 AM
No, it was a little sheet metal nut that got sucked in. I have already got it out, and the head back on. I have just not had time to get it buttoned up completely. .
QUOTE(stugray @ May 17 2011, 09:52 AM)
Stu
I was working on the passenger side head, you can t get the head completely off because of the tin for the oil cooler, but you can separate the head from the cylinders a couple inches which is all you need to remove a screw or something.
Drums66
May 18 2011, 04:45 PM
.......Good deal glad you got it!!!
(boing)
ewdysar
May 18 2011, 06:15 PM
QUOTE(theo @ May 18 2011, 10:20 AM)
Stu
Nice work! Good calls all the way around (except maybe the lack of rags in the intake). Congrats on catching this before things took a worse turn.
theo
May 22 2011, 02:56 AM
this weekend I finally got everything buttoned up; head, exhaust carbs back on. I adjusted the valves, looked at the pushrods on the cylinder i did work , everything seemed normal. i made sure the carbs were synced up as well. anyway when the car is warmed up I am getting quite a bit of smoke coming from the carbs on the side I did the work. (coming from both the front and the back butterfly valves). I need to get a new gasket as I don’t think its baking a great seal. but any reason why it would smoke? (smells like oil) ive not dialed in the timing but I wouldn’t think it would affect only one half of the engine...... the more I think about it, is it likely that the poor seal between the carb and the head is making it too lean and causing a backfire and smoke in the carb?
