QUOTE(skline @ May 30 2004, 08:54 PM)
Does it matter which 3/4 hose goes to which side of the pump? Also, is anyone else running a Rod Simpson Radiator and hoses? I know the RH uses 1" and 1 1/4" hoses. This setup from RS came with 1" and 3/4" hose. Should I run it like that or go get some 1 1/4" hose to run with the 1" down the center? Come on guys, it is so close I can feel it and hear it running in my sleep.
Scott,
With the Renegade water pump, water discharged from outlets can go to either side of block. Route/install to provide the cleareast path to block without making contact with headers, brackets etc.. This should be the same with any of the conversion water pumps available.
Since you went with a RS radiator, I'd use the hose sizes recommended by them. Glad to see you've decided to route down center of chassis!
What on the engine do you want to see that has not been shown over on the Bird site?
John
