QUOTE(StratPlayer @ May 17 2011, 12:04 PM)
This is where I located my fuel pressure gauge..76 D-jet
put mine in same place as yours saturday.
seems to be holding a steady 29.
now is running with new hotspark module and new coil.
can't get timing right(valves had been set and timing 500miles ago) and at that time idle was smooth at 1000 when warm, cant get it under 1500 with out loosing smooth idle and having the up and down surge.
no vacuum leak, - going off same mark as before tried setting timing at 3500 rpm but cant turn the distributor far enough to get it there.
should i adjust the dial on the timing light? should it be adjusted to a specific advance or be left at zero?
could it be the distributor was put in 180 off? it would't run then would it?
always something.
