Just ask me Ben.
I know that you want to do a six one day. I wont buy anything out from under you and I'll let you know if you actually need the part.
B
B
Here's my plan:
Six conversion using rebuild (late) 2.7 with JE 9.5:1 pistons, tall cams, and PEFI for induction.
Here's what I've got: (all this for about $1,200 including the running PEFI on the -4 )
PEFI/ignition (already running on my -4)
late 7R-case 2.7 with 2 pulled studs. JP is hooking me up with his machinist in Portland.
914-6 flywheel
914-6 engine tin
KEP stageII clutch plate
headers & muffler
What I think I need:
Have engine machine work done this summer
Rebuild the engine this fall/winter
oil tank & lines
oil cooler & lines
front engine mount & hardware
clutch plate
intake (several decisions to be made here)
911 tachometer
oil temp guage
11-blade fan
alternator mount/fan-ring (missing when engine picked up - might turn up)
Am I missing anything big?
Intake - the big question. I've got the PEFI/ignition, but need to decide whether to use a 3.2 style plenum/runner intake manifold or build something with six throttlebodies. We all know which would be easier, but... GSXR 1000 throttlebodies have just the right bore size. Get two sets, lop the fourth TB off the end, and (ta-da!) - triple-throat throttlebodies with TPS, linkage, and injector bungs. Hmmmm..... Ok, back to reality. Will a 3.2 intake manifold bolt up to a 2.7 or did the spacings change?
-Ben M.
