QUOTE(Bleyseng @ Jun 1 2004, 06:20 AM)
To check the dizzy remove it and see if it has any side to side play on the shaft. How much does the timing mark jump around when you time it? The mark should be steady not a 1" blur.
Geoff
I just played with the timing yesterday. I have a rebuilt distributer, with Pertronix installed, from a reputable shop, and my timing mark is NOT "rock steady". The dizzy shaft also has a little side to side play.
I queried the shop and was told, "the dist has to have a little play or it will bind. The bounce is probably in the engine, timing gear play on crank, where it meets the dist drive gear. Very few motors that we time have a rock solid timing. Most jump around a few degrees, and that is ok."
So my understanding is, that unless the engine is newly rebuilt, you'll have a little bit of bounce with the timing no matter how good your distributer is....
